Original Underseal coming off what do i do ..Take it easy with me please lol
Hi while I have been replacing front shock's and spring's and steering arm I have noticed in a few place's some of the factory under seal has lifted in a few place's.
It Is quite thick rubber under seal am sure I can not get this of the shelf at hellfords ? will be treating the rust first where water had got in under the seal then paint with epoxy mastic that I use on my beetle's great stuff by the way...
So basically want good underseal to finish the job off what have you used in the past ? has it done the job ok ?
Thank you for your time :-D
  • Replies 10
  • Views 1.6k
I've always used hammerite, seems to do the job
Yea I did see that but was not sure as have never done the underseal thing before lol ...
Hammerite Waxoyl over epoxymastic will do a good job
Sometimes waxoyl gets a bit of bad press because people say it traps water, I've never really experienced this but you definitely won't with epoxymastic under it :-)
I forgot about the waxoyl, when my dad restored his beetle's his final coat would be waxoyl come spring every year he would strip it back and recoat ...
I Love EPOXYMASTIC :-o
id epoxy mastic the scab areas then gloss paint the whole area body colour ...makes it easy to spot any new problems and washes down easy
i dont like thick underseal as it can hide problems until its too late
Not sure I get you ? the area is under the front wheel arch its only a few small areas ...
Theres paint called jotamastic which is pretty much the same only costs less :)
I think what steveo means is if you put waxoyl on you wont be able to see any rot thats formed underneith, but if you do it in a hard gloss black you can wash all the crap off to see what condition its in.
yep just that
jotamastic /epoxymastic over the cleaned up rusty metal ...then a top coat of gloss paint so it looks much like the would have when new
then once in a while clean it all up and its easy to spot any further rusting etc .. underseal etc often justs hides the rust rather than sort it
Oh I got you boss lol as for the jotamastic am sure you can only apply by spray gun ? as for the epoxy 121 you can apply by brush ...
Nope think you can apply jotamastic by brush, its used alot on boats etc
