Fitting remote central locking to polo 9n3
Hi, i have just bought a 2008 polo tdi and would like to know the best way to fit remote central locking to it? It already has central locking? does anyone have a guide to fitting it? Thanks everyone.
  • Replies 11
  • Views 17.7k
Hi Craig I am also finkin about fitting remote lockin on my 2004 TDi polo there are quite a few on flea bay from 24 quid (can be used to operate on 4-5 doors) but I am unsure which to go for will let you know which I opt for
Big Al
Hi, yes let me know that would be great. Do you know if they are easy to fit?
I have asked the question of one supplier so hopefully I will know tomorrow don't think it will be that difficult though
Big Al
Edited by Big Al
Did the 9n3 really not come with remote locking? Would have thought it would have been standard equipment tbh lol
Presuming your central locking is electric, it's a dodal to fit, just wire you exsisting motors in the new receiver and job done.
I bought a kit recently of eBay for 19quid, with four motors and all the wiring ect.
Spend half a day fitting it to my jetta, worked for the first five or so times then gave up the ghost, the remote doesn't operate the motors nor does operating the drivers door pin. Bag of wank ahaha
Edited by MaxVW
Can you name and shame the sham who sold you this crap so I don't go down the same route
Big Al
Big Al
I cant believe its not fitted as standard!! I dont suppose it would be as simple as getting a key fob and coding it to my vehicle? the car wouldnt have the remote locking kit already installed in the factory i suppose?
I just fitted an rclick kit. Was easy once I found the wires. http://www.rclick.co.uk/product_info.php?cPath=50&products_id=1112
Quick guide:
Remove drivers door card
Find Red/Yellow wire to electric window motor - this is your positive feed.
Find blue/white wire going to lock - this is your central locking wire.
You will need to get a 180ohm resistor (Maplin - 32p). Get some terminal blocks whilst there - save the pain of soldering.
Check wiring guide here - http://f.shortnd.it/ukp/vw_polo.pdf
Good Luck!
Hi,
Thanks for the advice for this - just purchased the rclick kit.
My 06 Polo Club doesn't have electric windows - any suggestions as to what to use instead as a positive feed in?!
D
