vagtacho access denied
trying to obtain my pin for programming a new key, using the following guide. but I'm getting the following error when connecting via vagtacho:
Connecting VDO New...
OK
6Q0920900 KOMBI+WEGFAHRSP VDO V11
Check for VDO tacho...
Tacho is VDO! Try to log in... Please wait!
Software Version: VSQX01LM
Password: 0
Check for Seed-Key...
Please Wait....trying to calculate Key
Seed-key mode: 03
Selected ECU Not Found! Try again or Select other ECU!
!!! Access DENIED !!!
currently using vagtacho 3.01, would it make any difference if using 2.5?
  • Views 5.4k
Have you tried other ecu types? From memory I had trouble with VDO new and ended up getting locked out of the immobi
Didn't work at all for me.
Luckily I code keys for people so I just got out my Supervagplus 2.0 and it read the skc within a few seconds. Double checked it on the ecu and then could login to the immobiliser (not the clocks as that'll lock you out), no problem.
Hmm. haven't heard of supervag.
After reading up on it it seams a good bit if kit.
Would you reconend this? As from experience vagtacho is a pita and doesn't work most of the time. What other uses does it have as most of the descriptions are quite vague.
