will my car fail mot if thers rust in the middle of drivers door?
in the middle of moving houses haven't got time to sort it. will it fail?
cheers
  • Replies 10
  • Views 1k
depends how bad it is, if its just surface then no, if you can poke your finger through it then probably
well the paint has come off and its just rust. but I've taped it with a small hammer and it didnt go through
should be fine
You'll be fine, if its not holed then don't worry
Pretty sure doors aren't suspension mount/seatbelt mount prescribed areas anyway?
do what we used to do with the transit, the guy in the garage actually told us if you cover it with tape there not allowed to take it off. should of seen this van all the arches were covered with fragile tape lol
Edited by mrbenpololoon
Aslong as there are no sharp edges they are usually fine hencevyou see gaffer taped wheel arches
A door would be fine any way as its not structural, it would just need to be covered up so no sharp edges are on show for pedestrian protection. Wouldn't want anyone you might run over getting tetanus now would we?
Yep cover it in tape the mot handbook said rust within 30 cm of a suspension
Or anchorage point is a fail but use tape moters arnt allowd to remove anything
Including wheel trims ect to check the brakes lol
No, but you can check brake wear from the back when it's on the left easily enough.
As for the rust on the door. Doors aren't viewed as structural, so it's only a problem if it's a sharp edge. Tape, filler, fibreglass, do what you want so long as it's not sharp. Arguably, if it fails on it, just take the door off, and put it back through. I've seen it done with a soft top Suzuki Jeep with a flip down windscreen that failed on wiperblades and screenwash. The bloke unbolted the screen and the wiper arms and put it back through.
Put tape over it had no advisories :-)
