Mk2 speedo light
Do all mk2's come with speedo light because I've replaced the fuse and I can't find the bulb for it, does anyone know where I could find it?
  • Replies 8
  • Views 967
there are 2 bulbs in the top of the clocks with a green strip or paper sorta shit to diffuse the light
as eric said, they just twist out. think youve gotta pull the clocks foward which is simple enough anyway.
think they are a 509t partnumber bulb, which is pretty universal iirc!
Cheers guys, I'll have a route around tomorrow
Replaced the bulbs and still nothing
They're really crap, did you have a look at night? as they're almost impossible to see in the day
Yeah I especially waited until night because old polos are known for their amazing lights and brakes. It had a bit of a funny connection to the clocks anyway, would that cause any problem?
on my mates mk2 golf we blew a load of bulbs trying them out without disconnecting the battery. I have got away with it before in my polo but i would try that with fresh bulbs.
Also, there are two types... blue and black plastic but they both fit. One is about 3 times brighter than the other but i'm not 100% sure which way around it is. think it's blue that is the brightest.
Sure you haven't adjusted the dimmer on the headlight switch by mistake?
