Polo 6n 421 exhaust will it if a mk2f gt
What mod would i have to do tomake it work
  • Views 530
Sell the 4-2-1 and buy a MK3 one, Its easy to do it that way and you might make cash, too much work , What 6n is it?
As long as its an 8v one then yes, some considerations need to be made with joining to the rest of the system
Welding not a problem just making sure they will fit . I see the hole sizes between the cylinder head and manifold but that should not be a problem as i got the 6n 421 cheaper than a mrk 2version
Yeah 8v one bolt to head fine.
Don't know if you'd need ARB blocks to clear it or not though.
They come with a length of pipe which bolts to the flange, should just be able to chop that to length and weld it to your centre section
Exactly what i thought whats arb blocks
