6n2 interior bits wont budge.
Ok so I want to spray the centre console, air vents and door panels to match the colour of my car. I have got the door panels off but am finding it hard to find a DIY on how to remove the Centre and vents. Please tell me I dont have to remove the full dash? Could someone explain how or guide me to a guide. I've looked for hours to find a decent one with no Luck. THANKS!
Left vent: pull.
Right vent: push headlight switch in, turn to the right a bit, pull out, detach cables, undo torx bolt (T25 I think), pull.
Centre console: remove stereo, couple more torx bolts, pull.
The 'T' piece at the top (windscreen heater vent) is clipped in at either side, the rest is plastic welds that you need to carefully break, you'll need to trim the welds back & glue it back in when you're done.
Thanks mate, I'm ill give it a go tomorrow :) I heard the T bit is a pain... hopefully it all goes smoothly! It would look daft with the centre done and not the T bit aswell :/
You're going to paint the door cards?
No the handle surrounds.
