Refitting glass
So I've looked at a few guides and think I know how this works. Anyone got any tips? I need to do both sides, front and back. I this a two man job?
  • Views 795
Depends how gung-ho you are. I use a rubber mallet.
bit of string round the inside of the seal, push glss in place and pull string from inside car to pop the seal over
or use speaker cable if your a pikey like me
I did read that insulated electrical wire is better than string actually. Why do you need to do it from the inside? Surely from the outside you can push downs lite to help it in a bit
Needs to be from inside because the outer lip's too big too flip over the frame. Start at the back bottom corner. Don't use fairy liquid to lubricate the seal because it will eat the paint and cause rust on the frame when it sits in there. I normally use screen wash or silicon spray (or cheap furniture polish if I've run out).
Hmmm, couldn't get this too work. Every time I pulled the string, it just came out the seal :? Got pissed off in the end
Helps if you get a mate to push on the screen
