Well I've worked out I'm not the sharpest tool in the box.
I finished work yesterday at 3pm and dropped my mate off home then i got home about 3:45pm.
I needed to move my car so at midnight i went out to it and saw i left the sidelights on
I then go up to the car and nope dead as a dodo,so i undo the drivers window push the car backwards as there was a car right in front of me then had to push it over a big lump in the road then off i went running down the road at midnight with my car. I then jumped in stuck it in second and released the clutch and it sprang into life.
I did say well thats never going to happen again but i give it a week
The car is a mk2f so it doesnt make a noise with the lights on while the door is open.
  • Replies 9
  • Views 928
weve all been there haha.
i found a kit online somewheree possibly ebay? for installing a warning buzzer
I think thats a good idea, Ill have to look into it. I get paid friday so ill buy one then thanks.
Bit of a nightmare, had people remind me in car parks that my lights are still on, probably thinking I'm an idiot but I don't have an alarm like them!
I had my mate say to me when we got out at work. Your lights are on so I should have known better but oh no
Wouldn't be too hard to rig one up.
It's just a switch on the door that completes a curcuit when the door is open if the lights are on.
Just find a car in the scrappy with that feature and steal the switch and wiring, wire it up to the headlight switch and a buzzer and that should be that.
To save adding another switch, couldn't you rig it to the drivers courtesy light switch?
Power feed from light switch to buzzer.
Off the buzzer onto the ground for the door switch.
Door opens, lights are off, the buzzer sees ground, but no 12v feed.
Turn the lights on, the buzzer sees 12v, but no ground, until the door is opened.
Might need another switch on the door, depending on the wiring on the door switch currently. (lol, CURRENTly) :lol:
Job done.
Relay 38 on a late spec golf mk3, or relay 88 from an old school Audi, it gives a different ring.
I used a Velleman K3505 electronics kit (some assembly skill required)
It wires off ignition switched live and lights. I connected it to interior lights so I can use the dash dimmer as a volume control
if I've turned the engine off in a queue, so still have sidelights and rear lights lit, but want to quieten the happy chirping
Not had a flat battery due to lights in ages.
I've managed to run battery down with muted radio left on all weekend though!
