AFH Parts
Still got a few bits around that i need to shift.
AFH/ G40 Luk clutch pressure plate brand new £20,
AFH/G40 Luk clutch pressure and friction plates with 6k on them - £20. You can have this friction with the new pressure plate if you want too.
AFH block with 60k on it, clean and polished on the sump side. STD Main bearings are fitted as i plastigauged the crank so they cant really be used elsewhere but i still do have the crank for sale too. - Offers
New Cambelt tensioner and roller made by INA - £20 each
Pistons and rods all balanced, STD bearings fitted as i plastigauged to crank, new bolts. No piston rings though. - £50
AFH Cambelt drive/crank pulley, Alternator drive pulley and alternator pulley - Offers
2 x AFH cam seals - £10
PM with questions or offers, Location is Leicester, will not post block/crank/rods and pistons the other stuff i can.
Edited by Polo_Gen
  • Views 344
il take the gasket.
  • 5 weeks later...
bump
some clutch parts added
Would you have an oil pick up for a later style AFH? The one with a direct driven oil pump?
no sorry this was an early type engine with the chain driven pump
