6n2 8v parts
hi all,
I'm having a bit of a clear out so these have to go. they are most from my old 6n2 engine which was rebuilt and ran great until the oil pump failed.
engine code is AUD but is the same AKK
air filter/ engine cover - decent condition some very minor scratches but is complete. has no filter panels inside.
£10 collected
- AUD inlet manifold - has brake booster pipe, but the plastic end piece is missing. has map sensor and return valve. also the rubber o rings are new.
£15 collected
- upper cam cover - usual condition, still has the engine number sticker on all clips attached.
£5 collected
- oil breather- for mos small block engines- has been cleaned out worked perfect and includes a recent pipe (£14 from vw)
£10 collected
- AUD/AKK bosch ecu p/n:030 906 032 DT perfect working order.
£10 collected
- AUD/AKK fuel rail, regulator and injectors. perfect working order, mounts intact. imjectors where serviced with less then 100 miles use (£35 for all four) and the pipe on the reg is new.
£15 collected
- AUD/AKK HT leads, less then 50 miles use. no damage or faults etc.
£15 collected
- AUD/AKK gates timing belt and tensioner - use, but for less then 100 miles so plenty of life left.
£20 collected
- various brackets. coil, engine hoist etc. all perfectly usable
£1 each
- AUD/AKK breather pipes, valve and polished bracket. pipes are all recent and in total cost over £30 from vw. VERY common failing point. grab a bargain
£10 collected
- AEX/APQ + many others- fuel rail, regulator and injectors. again these injectors where serviced some time ago and where not used (thought it would fit the AUD) perfect working order
£15 collected
- AUD/AKK engine wiring harness - used condition, perfect working order no broken clips etc. bracket is a littler rusty.
£10 collected
- alternator bracket for most polos. used condition. for non ac cars bearing has been re greased
£10 collected
- sump, was originally from an AUB and seems to be recent. no damage.should fit most small block engines.
£15 collected
- AUd/AKK exhaust manifold, with the pre cat taken out. this was cut in half and the insides burned out then welded back up and sealed. the inside is pretty smooth and seems a good job. has some heat wrap around it. imho it made the 8v a little nippier and didn't bring up any errors and past the mot fine with it on. i did have to replace the lambda though. (lambda not included)
£30 collected
- AUD/AKK cylinder head, this has been rebuilt, skimmed all new seals and the guy who did it mentioned something about the valves. he may have changed some of them i will have to ask him.tappets and rollers were changed recently and worked spot on was quieter.the cam looks to have minor scoring on the bearing faces.
£50 collected
- AEX/APQ + many others engine mount plate. can be made to fit AUD but will need triming.
£5 collected
- 6n/2 power steering pump. good working order.
£5 collected
- 6n rod change linkage. perfect if you have a late polo and want to fit an early g/box. was rebuilt recently and worked perfectly.will include the selector finger.
£20 collected
- early polo EHB gearbox. was opened and checked, no damage at all (rare) and was great to drive. no fifth gear problems. will need an early linkage or adapter to fit a late 6n/2, has recent good quality gear oil and lucas oil additive already topped up ready to go. new selector seal fitted less then 100 miles use.
£100 collected
- 6n 16v smoked rear lights. one appears to be different. one has a bit missing where theboot shuts but shouldn't effect the function of it.
£30 collected
will update when i find more bits.
i am located in new romney, kent. welcome to come and collect bits, but i am also happy to post all these items, please contact me and i will get a price.
OPEN TO OFFERS ON ALL ITEMS, please just get in contact and say how much you want to pay for it :)
danke
  • Views 179
Popular Days
Would you post the breather pipes, valve and polished bracket to Stoke?
