Removing the boot VW badge... HELP PLEASE
I cant figure out a way or removing the boot VW badge without bodging it off. I'm only wanting to take the VW emblem off the circle surround so I can spray the background. Has anyone done this? :nod:
  • Replies 9
  • Views 913
Which model? On my mk2f it just pops out, there's 2 little clips holding it in.
6N2 GTI mate
Grab a hair dryer and use it to heat up the glue behind it then grab a credit card or some fishing wire and slide that behind it and wiggle it about when the glue is soft enough and it should just come off.
Then just clean off the excess glue (I used some bug & tar remover to do it).
A hairdrier? I just stuck my fingers behind it and pulled. Clean off the glue as best you can. The badge comes apart also - the back and the front. Scratch up, paint, glue together, glue and then back on the car.
You can just pull it off, but heating it up a bit with a hair dryer softens the glue so its even easier to pull off.
Cheers guys, same procedure really as taking off the boot logo
Dental floss also helps, run it between the badge and bootlid
I just pulled and used a credit card to help seperate the glue.
Nail varnish remover works well at removing the glue left behind, but wipe it after.
There were so many clips on the badge it was unreal! Nearly broke the VW sign... Not good. All done just have to stick it back on
