Wing Mirror switch wiring
So, I'm doing an interior conversion from 6n to 6n2
I've changed the doorcards, which also means fitting the 6n2 wing mirror switch
only problem is, the 6n2 switch is a 10 pin plug (9 wires) while the 6n version is 8 pin (8 wires)
I know which is my Ground and Live, but the other colours just don't seem to match up.
I did figure an ingenious plan whereby routing each 6n2 wire to the 6n LED wire would light the dash up when a circuit was created, thus allowing to figure out which wire did what, but my results are pretty meaningless.
so far I have
Red to Grey = Left and Right Up position
Blue = No Position
Blue/Grey = Fuck Knows What (LED?)
Purple/Grey(knotted)= Right Side Right Movement
Purple/Grey = Left Side Down and Right Movement
Purple(knotted) = Right Side Left Movement
Purple = Left Side Left Movement
Black =Live
Brown = Ground
So this is all well and good because I know what each wire on the switch does (or doesn't)
But I don't know which wire that relates to on the 6n wiring
Essentially now I have 8 (maybe 7) wires to go to 6 pins
I have had them working as in, the motors move when I move the switch, but it'll be some daft combination like, Left Side Down Movement makes both mirrors move inwards towards the car and up
or maybe the good old Right Side Right Movement makes the Left mirror go down
so yeah, any helpful suggestions would be much much appreciated
thanks
  • Views 6.6k
6N2
Pin 1 Blue Switched supply to Heated mirror relay
Pin 2 Red/White to Drivers Mirror pin 7 & Pass Mirror pin 7 (Grey wire)
Pin 3 Brown (ground/earth)
Pin 4 Grey/Blue Backlighting Supply
Pin 5 Black (Ignition supply)
Pin 6 Grey/Lilac to Drivers Mirror pin 8 (motor common)
Pin 7 Lilac to Pass mirror pin 6
Pin 8 No Connection
Pin 9 Lilac to Drivers Mirror pin 6
Pin 10 Grey/Lilac to Pass Mirror pin 8 (motor common)
Mirrors pin 4 Ground/Earth
Mirrors pin 5 Heater supply (Black wire on 6N2 from Heated mirror relay)
6N
Pin 1 Brown/White to Drivers Mirror pin 2 (motor common)
Pin 2 Grey/Blue Backlighting Supply
Pin 3 Brown/Yellow to Pass Mirror pin 2 (motor common)
Pin 4 Blue to both Mirrors pin 3 (L/R motor)
Pin 5 Black/White Drivers Mirror pin 1 (UP/DN motor)
Pin 6 Black (Ignition Supply)
Pin 7 Black/Yellow to Pass Mirror pin 1 (UP/DN motor)
Pin 8 Brown (Ground/Earth)
Mirrors pin 5 Ground/Earth
Mirrors pin 4 Heater supply (White wire from HRW switch)
Edited by nige8021
ooooh thanks!
where did you find this information?
Edited by R10tz0r
ooooh thanks!
ElsaWin & Haynes :-)
QUOTE (R10tz0r @ Friday 30th August 2013 - 7:37am) <{POST_SNAPBACK}>
ooooh thanks!
Thanks dude! sorted it over the weekend!
