arch rolling on polo coupe
just been in contact with arch-enemy and just wanted to know if anyone had this problem when with arches rolled on a polo coupe - my car doesn't have the gt/g40 trims so if I don't put these on will it cause some damage?
I had my car resprayed on both sides 2 years ago-
bit worried that I'm lowering the car further10-15mm and do not want the arches to catch on wheels and do not want to damage the bodywork as it is currently perfect!
I got this reply from arch-enemy:
If you aren't putting trims on it won't roll well. There are holes around the arches of all these cars to attach those trims. When you roll the arches they distort at each hole. Worse, the hole can snap across the lip and make the distortion worse. So I don't usually roll the arches on these unless either the trims are going back on, or you are about to repay it, as the fronts will need some filler.
I need a flat surface, can't do it on a path or a road, sorry
----- Original Message ----
thanks.
Edited by koolspot
  • Replies 8
  • Views 1k
Thats bullcrap, I've had mine roller on my old car, I've got my own tool and all my mates borrow it and roller there cars which are newer, I don't have trims either!
I thought arch-enemy were one of the best so didn't expect for him to reply that.
I have seen other polo's rolled and it seemed ok!
what are the chances of him damaging my paint work??
I spoke to someone else and they said the fronts need to be heated up to roll and because they are painted it may crack the paint!
that's no good to me right now as that's the last thing I want to happen before players on Sunday!!
another place said that the fronts on polo coupes are not rolled but angle grinded off and them sealed up as its a single layer.
Edited by koolspot
I had to fill and respray my arches on my old coupe when I rolled it due to exactly what he says. I couldn't get it to roll evenly which also caused the paint to crack.
If you do it slowley and heat the paint up well then you should be fine, At the end of the day Arch Enemy was going to come out and do my coupe, I don't have trims so maybe your area roller is a pussey haha!
lol...
it was the main guy you see on the website - PHIL.
well I think they have refused to do it as they have stopped replying to my emails.
style dynamics in Hayes said try can do but may grind the arches to save them rolling and cracking paint.
fingers crossed when the wheels do go on after lowering the arches will be ok lol....
Scaffold pole it lol
lol no way!!
have u seen the clips on you tube - arch rolling gone wrong!
messed up!
Haa, my rears are grinded, previous owner did it, rust free ATM!
