Is this easily repairable?
Bumper has a crack in it and its just started to get a bit bigger so I want it sorting. Is it easily repairable?
I also want the boss that the number plate sits in, anybody had this done and how much is it ish?
Body shop will repair that cheap I would imagine, could aswell a do it yourself with some filler and paints.
Why do you mean with the plate? You want it smoothing or the bumping strip building up?
Ahh right that's sound! And the bump strip filling in, where the number plate sits like
Cheers!
Not really sure on price for that couldn't see it being any more then £80-100 I would imagine though
Awesome shall give a few places a ring tomorrow see what they can do for me
Luke if you do it yourself, be sure to go over the crack with a soldering iron to plastic weld it before you put any filler on, less chance of cracking !
To stop a crack you need to heat it up and fleck it so you can find the crack end there's probaly a weak spot in the bumper now. Then drill holes at the end of the crack the fill with plastic weld smooth down then fill with that flexible filler. As for bump strips un sure about that
