Boot Doesn't open with central locking - POLO 6N
Hi guys,
I couldn't find any posts describing my problem so I apologise if this has already been covered.
Basically when I use the key in the doors, the central locking unlocks all of the doors and the petrol flap, but not the boot.
I have to use the key in the boot to unlock it, however this doesn't work unless the central locking has been unlocked first.
Does anybody know what might be causing this?
Many thanks
  • Views 5.5k
You need to have the boot in the unlocked postion then lock the door and it will lock/unlock boot via door
So basically unlock doors then manually unlock boot then lock door without relocking boot and try
At some point either you or previous owner has locked the boot manually after using key in door
Also you can't open the boot without the doors being unlocked... Period, just how it is
