door locks not working
My sister has just bought a 1999 1.0 polo and both doors will not lock. The barrel just spins. Do all of the polo 3 have central locking?
  • Views 681
If the barrel is spinning it will be the tang on the end of the barrel snapped off ( common fault) repair kits on ebay/ main dealer/ TPS
Not all had c/locking, have a look in the boot behind the RH carpet trim you might find a black box with a plastic pipe comming out of it, if there is you have c/locking, but as the barrels are spinning they won't be making the switch in the door locks to signal the pump to work
Ok so i fit a barrel repair kit today to find that when putting the handle back into drivers door the paddle part should fit into a slot, however there appears to be a hole the size of a 5p. Baffled now.
Any suggestions.
The slot is in that hole
