Blooming hell
OK so I'm driving to work in my mk2f coupe and bang a lorry chucks up a stone and it hits my windscreen.
Scared me but now I have a crack. It's only about 2 inches long but it's splintered off looks like a spider with its legs. Pretty miffed but hey ho. I now need to find a windscreen and fit it.
Is fitting a windscreen on one of these easy? Any advice please. I just don't want to have to spend close on 200 for one. Thanks Thomas
  • Views 840
  • Ha I had the same going to GTI spring fest but it was another polo that fired it at me (think it was brett?) a decent second hand screen shouldn't really cost more than about £20. Kick your old one o
a decent second hand screen shouldn't really cost more than about £20. Kick your old one out so the rubber isn't damaged trying to remove it and then use the string trick to help fit the new screen
a man with an impressive moustache will take it from here...
thanks i will try that I'm over the mainland in november so hopefully be able to get 1 and fit it then. thanks again
Shop around. Mk2 windscreens are nothing like £200.
They're less than a ton new from VW, or were last time I had one
Got one for £95 fitted just 2 weeks ago.
The string tricks easy enough to do. Done it a couple of times on mine but make sure you remove tax disk holders etc as i didnt when i removed my old one and lost the clip on the back :(
