MK4 overhead console switch
Hey guys,
There is a light switch button located at the overhead console malfunction.
The button is in the ON position all time. When I press in down to off it and it doesn't hold.
So my temporary solution is to apply masking tape to hold it down.
I think the console will need to be remove to veirfy the issue.
Has anyone remove the overhead console before? If yes, mind to share the steps to do it.
Thank you in advance.
Sample of the button:
$T2eC16h,!zUE9s39!fTSBR7yzij5kg~~60_57.J
  • Views 737
I removed one on a passat and they look similar if you pop the to grills of you will find two torque screws undo these then it just pops of
