Things to look for when buying a mk2 bready
Off to look at my first car on sunday and thought i would ask on here about any common problems to look for. Cheers guys
  • Replies 10
  • Views 942
Rust - Rear arches, area behind fuel filler, fuel filler neck itself, sills, check the rear foot wells, they rust out around the bungs, battery tray
Check that the alternator isnt covered in oil, tell tale sign the head gasket is leaking
Obviously check for mayo in the oil filler cap, which also can mean the head gasket is blown
Check heater works on all 3 speeds
I can't think of very much more, rust is the main issue, even things like head gasket are cheap and easy to fix, just watch out for rust
Colour - dark ones rust slower
Rust, especcially:
- At the back of the sills, escpeccially the drivers.
- On the fuel tank filler neck
- On the front and rear valances
- In the battery tray
- On the rear exhaust hangers
Electrics - there aren't man, and they're pretty reliable, but it's worth going round and checking everything
Engine
- An oil leak from the cam cover gasket is pretty common and a 5 quid 15 minute job to, however, be careful it's not hiding...
- An oil leak from the head gasket, normally at the front corner. Can be one of those faults you fight forever, although you might be lucky and just be able to teak the headbolts up a bit more
- Carb, Pierburgs come in for a lot of bad press because they're complex and don't get serviced, so make sure it runs and idles well hot and cold
Previous owners, and their bodges and mods.
Pretty much the biggest battle, especcially if they thought it was a good idea to slam the car. The floor gets hammered, suspension wears faster (especcially if they've fitted a hard riding new kit on 30 year old suspension bushes), and people hack lumps out of the chassis leg to clear the drive shaft.
Anything else is pretty easily sorted with a haynes, this site, and basic tools.
Cheers for the information guys, as for previous owner mods i should be safe as i've seen it round where i live for a few months and its totally standard and pretty low milage for the age. I'm sure i seen some patches of rust tho but hopefully not too serious. I'll see if my brothers mate will come along as he's had 4 mk2 bready (sadly he scraped them all)
Went and seen it today looks clean, some rust on the arches and at the back of the driver sill but doesent look to major. Should be picking it up soon :)
Nice one :D
Did you check the filler neck? It's rare just that corner rusts without the tank being affected?
Yeah mate its all good, the guy said its had a new fuel tank a few years ago. The battery tray is clean aswell. :)
Sounds good if its had a new fuel tank and the battery tray is not corroded thru. Nice one. I would have said main things to look out for were the fuel tank, jacking points at the back. Sills there take a hammering usually from rushing tyre fitters slamming jack OFF the jacking points. Then corrosion takes place. The typical oil leaks front left (dripping onto the alternator) are typical of them cars but I mean cmon look how old they are. If u get onewithout a leak these days you are lucky. I would be quite happy to take a mrk2 with a head gasket oil leak or a blown head gasket. it really is a easy (although time consuming) fix. If the fuel tank has been replaced I'm guessing its been looked after to a decent degree and maintained. Stick some pics up m8 let us all have a look. Long live mrk2 fans!!!!! Looking under the oil cap , if u do see mayo then its usually the reason the car is being sold and usually why its been sold so cheap. ALL GOOD :-)
yeah seems like a pretty good deal, guy has a genuine reason for sale, i'll get some up when she mine (hopefully) :D
Cool cool. It the tank's still in grey/silver paint, get it coated in something better, because that transit primer doesn't last.
