Wrapping 6n2 interior
so I've bought some sticker bomb sheets and i want to wrap my interior with these sheets. The parts i want to wrap are the smoother bits e.g. around the vents, door handles and centre console. Has anyone done this/similar before, if so any tips?
cheers Ben :)
  • Views 946
I've had a go at bits. It's not to hard make sure you use a hair dryer/ heat gun to make it stretchy and have plenty of vinyl so if it goes wrong at first you can redo it.
I did the top bit of the clock surround in gloss black vinyl the tip for that is to start from the center then work to one side then go to the other. And if you get a crease heat it lift it and stretch it out.
Edited by vdoubleu
