Swapping new for old steering column - mk2
Anyone done this? I've swapped the steering column from a newer model to an older one with the silly linkage. However it doesn't seem to be long enough and I can't get the clamp bolt on. The cut out on the steering rack is in the 'wrong' place. Do I need to swap for a later steering rack too?
  • Views 733
You mean a one piece telescopic one instead of the two piece? I swapped without issue, although I went backwards not forwards.
Yeah. I've fitted a one piece one, but its about half inch too short. Is there a way of lengthening them then, if they are telescopic?
Simon
It's just sleeved, so it compresses in a crash. Pop it in a vice and hit it with a hammer (outwards) to extend it again
I'm not sure how its gotten shorter though, I took it off the car and I haven't compressed it. Which bit do i put in the vice and which bit should I hit?
Put the inner (smaller end) in the vice and somehow hit the outer to draw it out
the cut out will move as you either move the wheels or sterring wheel to suit no?
