Pierberg Carb
I have for sale a Pierberg carb removed from a 1.3ltr 1990 mk2 polo.
When removed this carb was in working condition with no problems what so ever.The only problem, if you can call it that, is that one of the pins is missing from the top where the airbox bolts down. This could easily and very cheaply be replaced.
As you will see from the images the carb come with carb flange, through bolts and ring used for fixing to a standard airbox. The carb flange looks to be split around the outside edge, however this is only cosmetic.
Based in Leeds for collection.
£30 collected.
£45 posted due to weight.
Please PM any questions
  • Views 204
Hi, is this still available, Ide be interested at 40 posted,
Still available PM me if your interested.
