polo 9n hub nut size
anyone know the size, n/s side was 32mm bolt but the o/s looks totally different and as best i can measure its 35mm or 36mm, got a hold of a 3/4 drive socket set but the sockets are to thick to use so will need to buy a 1/2 drive socket and only want o buy one
  • Views 7.9k
If its the driveshaft nut mine is a 36mm 12 point socket that I use. Hope that helps
