Charged AFH
So who is it that has the supercharged AFH on here. I think it was Mikey?
  • Replies 15
  • Views 943
  • runforrestrun
    runforrestrun
    Because you get more power and torque by giving the engine 200cc more...?
  • 120 is what u get from a 1.4 16v on carbs and the hybrid sees 150 when set up correctly and 200+ is possible with cams and itbs
  • It's only about 175 with cams and ITBs on a 1600cc hybrid actually Heg123 car just got around this figure 200+ is boost territory
Not me, I carbed up a 1.6 version but never charged one, I second its viable as long as you foot io for silly boost. Keep it low pressure com happy days.
How would it be as a AFH/AVY hybrid? That makes better compression right :s after seeing Sams Lysholm mk3, I want a charger!
The hybrid would be worse for boosting as standard as it has a higher CR than the std AFH
So without boosting, why is the hybrid better than a standard AFH
the hybrid is a stroked AFH basically its 1600cc not 1400cc like the std AFH
the std AFH has a CR of 10.5:1
the Hybrid has a CR of 11.5:1
So why is it better to have a hybrid then. Especially if people are only running bike carbs and only getting 20bhp more. Why not keep it as a 1400
All costs money past 150bhp!!
It all costs money over standard bhp to be honest
:thumbsup:
Thought CR depended on what variant of 1.6 AFH you build?
Ie;
Stroked AFH - 11.5:1
Stroked AFH with AFH pistons - 12.3:1
AVY bottom + AFH head - 11:1
I was just saying the C.R. of the hybrid was higher than the AFH so would be harder to straight boost that was more my point
but the stroked afh and the afh head on the avy bottom end should be the same C.R as the blocks are identical castings near enough especially in height which is the important factor.
Edited by StinkyPete
A BHP figure doesn't reflect the extra torque. Depending on gearing, a 1.4 in the same tune may pull as much top end, the 1.6 just gets there quicker .
