Jim's Mk1 Berg Racer Build
Heres a teaser on the day I picked her up in August..
Updates to follow
Edited by runforrestrun
  • Replies 186
  • Views 42.6k
  • runforrestrun
    runforrestrun
    I've been a naughty boy.
  • runforrestrun
    runforrestrun
    I also took out the bulkhead divider as well, to make room for the throttle bodies at the back of the engine. Surprisingly, I was able to get it out with just a plumbers wrench (pliers) once I'd cut
  • runforrestrun
    runforrestrun
    Photo of an expensive box SEAT Ibiza timing belt cover High torque starter motor courtesy of Mr Croxford's group buy NOS Bosch headlamps VW Motorsport super 1600 4-2 exhaust manifold Fi
So, my plans (items still needed in are in italics)
Engine
AVY block drilled to accept AFH headbolts and roller tensioner pulley
AFH pistons
AVY rods and crank
Flowed AFH head (have the head, needs flowing)
Emerald management
PU side engine mounts with bilet alloy rear mount
VW Motorsport exhaust manifold
Vernier Cam Pulleys
Windage tray
High lift camshafts
Solid lifters
Centre exit exhaust
Jenvey throttle bodies
DCOE inlet manifold
Drivetrain
Lightened and balanced flywheel
Quaife G40 LSD
Uprated Driveshaft
Helix Organic Clutch
ATV Gearbox
CAE Ultra Shifter
Brakes/Wheels
Front - 256mm discs/Girling 54 Calipers/Audi 80 Carriers
Rear - 239mm discs/mk4 Golf Calipers/Mk2 Golf Carriers
Pedal Box
13 x 8 Compomotive CX350 3 piece modular wheels
Chassis/Suspension
GAZ Coilovers
G40 Steering rack
G40 rear beam
PPP length adjustable TCA's
PPP Stage 3 subframe
PPP front suspension turrets/top mounts
Full Berg style arches and GFK front spoiler
Rear diffuser
Rear Wing
mk2 Golf rear stub axles
Early mk1 Grille
Early mk1 Chrome bumpers
Single wiper
Full weld in cage
Gusseting/stitch welded seams
Interior
Flocked Dash
Bucket seats
Harnesses
As you can see, this is going to be the car I always dreamed of building.
Was this the one in vw mags a few years back
loving the plans for this! looks like a good car
I Like the shopping list and look forward to the updates :D
Windows all out
Little bit of rust on the rear boot surround
Repaired
Primed
Surface rust
Treated with POR 15
New GFK splitter
See you later wheel well
Arches pressure washed ready to be cut out and welded properly
Love the front splitter
Oh my.. :)
Now this will be a build thread to follow! :)
always wondered what happened to dr pepper polo.... Good work so far, excited to see this progress!
I now own a Quaife LSD and a G40 Gearbox. It's been an expensive week, and I put 450 miles on the car chasing these down. The work continues.
good job! id love to get a diff. pricey though!!
you should make a diffuser up for the rear, now that you have got rid of the wheel well the rear valance is gonna be like a parachute
Agree with Eric here, Yoof has some designs / got a diffuser laying around I think. Looking good though dude, have you had a think about spring rates yet? I'd also think about getting the camber adjustable TCA's from PPP aswell. What tyres are you thinking for the 10" wellers? Not stretch I hope!
the diffuser is already on my list of things to fabricate :smile:
I've not looked into spring rates yet but I know you need a very firm setup to run the stage 3.
Tyres wise, no stretch here, don't you worry about that.
I know I'm not giving much away here, but here's a few more photos.
I've now got a NOS pair of headlamps to add to the boxes of parts in my wardrobe too.
That little tang in the middle of the bottom panel was only there to use to earth against while I weld BTW.
Suspension wise mate, depends what you want from the car,
If it's purely track based and you don't care about skitting around on the road or it riding shite or having lift off I'm in a tree issues then hefty springs may be the one; however you should still be able to obtain some ride comfort and roll stiffness etc through other means, lack of a front ARB isn't ideal, but roll stiffness could be gained still, just depends obviously everything is a compromise but hit me up if you want some help/advise; but ideally need some figures such as unsprung masses etc but maybe able to work something out.
Thanks Nick, I'd planned on asking your advice! I'm gonna get it rolling on the coilovers that I've got and then I planned on setting it up using the corner weights etc and asking your advice, I sure don't want to lose this car to the same gremlin as my old mk2. It's not gonna be slammed anyway as with my splitter it'll catch on everything and drive like a dog.
Any more updates Jim?
It really does deepens on what you want from the car mate, a decent fast road setup will probably be shite on track, realistically a decent track setup will be a, shite on road, and b, dangerous on road lol!
I want it all!!
Small update
Passenger wheel arch is nearly finished now
I also have a rear valance
This is why I need one
And some inspiration.
Where does the super charger go? :P
Never saw that rust before you repaired it, spot on job mate :)
So the nearside wheel arch is pretty much finished.
Now comes decision time. I want to have a centre exit exhaust which means I will need to modify the valance and delete the factory cutout.
I will also need to finalise my plans for a fuel tank and filler neck solution too before I can start the offside arch as obviously it's designed with filler neck and fuel flap in mind. I can't use a factory tank if I have a centre exit as there won't be enough room for the pipe under the tank. Unless I use a factory mk2 tank (after retrofitting a mk2 handbrake) and route the pipe to the side and back to the centre, which will be crap.
Anyone got any ideas for a slimmer style tank that I can fit in the stock location?
cut the tank in half lol
I don't know why you don't just buy a decent fuel cell and mount it on top of the wheel well cover your welding it. Then use one of thowe factory vents on the quarter panel as a tank vent, just have to lift the boot up to fill it up, which is awesome :D then you can delete the pipe of doom and all the shit on the os arch and have centre exit exhaust
Get a baffled tank cell, or a decent swirl Pot and fuel pump
Nuke performance do some awesome stuff
