Jim's Mk1 Berg Racer Build
Another piece of the puzzle delivered today.
Girling 54 Calipers with early Audi Carriers to fit 256mm discs up front with OEM parts. Happy!
Dan (Higgo) is selling a set of Ferodo brake pads for a 256 set up, here's the link to his ad......http://www.clubpolo.co.uk/forum/index.php?showtopic=330251
  • Replies 186
  • Views 41.9k
  • runforrestrun
    runforrestrun
    I've been a naughty boy.
  • runforrestrun
    runforrestrun
    I also took out the bulkhead divider as well, to make room for the throttle bodies at the back of the engine. Surprisingly, I was able to get it out with just a plumbers wrench (pliers) once I'd cut
  • runforrestrun
    runforrestrun
    Photo of an expensive box SEAT Ibiza timing belt cover High torque starter motor courtesy of Mr Croxford's group buy NOS Bosch headlamps VW Motorsport super 1600 4-2 exhaust manifold Fi
are they not 64's?
are they not 64's?
No such thing, it's just how the old paint is sat.
Thanks dude, these are Audi brakes though not Vauxhalls :)
Delivered today, Simmo specials. Home brew Polo mk1 GT badges.
Any progress on this mate?
I've got a few more parts for the build, yes, but no building until my exams are done (20th June is the last one).
Purchased a used set of mk2 Golf rear stub axles, carriers, and mk4 Golf calipers to refurb
Handbrake cable adapters as I've settled on a cable handbrake, hydro not required
Mk1 Scirocco single wiper unit
Chrome front and rear bumpers
Vernier pulleys for the AFH cylinder head
Windage tray for the AVY bottom end.
Distributor blank courtesy of mr Pinches
E5AD67CD-232B-4816-812B-FCD3C7984AEF_1.j
Early dash, although too good to flock so I may end up using the facelift one
Front turret tops courtesy of PPP
Back space when running zero offset 10 x 13" rims
And what they look like from the outside. (Ignore the colour and the stretch)
In other news, I've got a quote today for the tyres, £144 each before VAT. Ouch.
Edited by runforrestrun
Good update! :)
I should have got a Windage tray for my bottom end... kinda regretting it now! I'll see how much oil gets kicked up into the breather :)
12CDBF9D-5F79-46B7-9B31-9DDD0B24F4D3_1.j
NOS Bosch headlamps
Fitted to the AFH block, also showing the engine mount adapter to utilise all three bolts, made by Stinkypete
Solid mount on PPP gearbox mount, courtesy of Mr Croxford
G-Lader rose jointed track control arms, just surface rust from storage
Solid driveshaft and lightened mk2 flywheel
Helix organic clutch, courtesy of Daryl
Quaife LSD
Good update! :)
I will be knife edging my crank as well before it is balanced, every little helps I reckon.
I take that back..
some brilliant updates!
Where get your exhaust manifold from?
I bought it from a guy on here - Polo_Gen I think his name is.
Hywel has one as do a few others, but I'm very lucky to have one too :)
Nice thread dude! You have given me a few ideas for my build (which I have yet to start)
This is going to be a beast when its finished!! great build thread and some excellent parts.
Have you trial fitted the windage tray yet Jim to makesure its got clearance on the crank and conrods
I had to modify my one I made extensively to clear it all and yours will have a longer stroke meaning more clearance needed
Haven't test fitted it yet Pete but I would be surprised if I didn't need to modify it.
I've got plenty to do first!
Yeah just giving you a heads up incase you planned to just fit it while building engine up
Looking great so far just a pity about exams and revision taking up a lot of your time
Yeah man, but not long to go now! My last exam is 20th June, and I want it in paint by the time I start my university course on 15th September. Should be achievable.
This is going to be awesome.
Just to note, that rear box mount is savage- keep a close eye on chassis, and I'd be tempted to beef up the rear gearbox mount (and if not already done stitch around the front box mount too).
Thanks for your words Pete!
I will be stitching the bay, and good idea, I will strengthen the rear mount as well! I'm not sure if it will be too rigid to use anyway, only one way to find out!
Why can I only like this once!!!! :-D
Epic!
So I started to paint my rear badge.
In primer.
Silver lettering is done. I don't like spraying metallic. It's a pain in the ass to get it right.
Oh, and this turned up, already! I'm going to be eating beans on toast for the rest of the month, but it's worth it.
Looking great mate, Awsome stick!
