Help with seatbelts
I have a 93 polo mk2f the seatbelts are in the front,complete along with back except for buckles?! I had a set of corsa ones lying around these don't fit the vw clasps, do 6n buckles fit on the mk2's clasps!?
  • Views 707
Not sure what you are saying here. Have your seatbelts had the buckles cut off? I have a set of rear seatbelts if that is what you are after/
I only need the buckles and a lap belt
Not sure if the belt will buckle up to a 6N receiver, but its worth a try, it might work !
If not, I'm sure they will with mk2 golf or mk3 golf depending on the age of the car, saying that there should be loads of mk2F's in local breakers.
