Kabel problem
Hi. I have A clarion vrx938r buy i missing A kabel. The och that belongs to the unit, A special cenet kabel. Nog A precise square one corner in rounded? Any one know?
  • Views 748
Popular Days
I also have been looking for a long time. Every time I ontact clarion Europe and USA about it and they take a while to search then cut off.
I have found that some alpine navigation systems use the same cable but i think that if alpine sell it alpne then it would be at least €100
I have bought two female pc VGA (monitor) connectors and i have soldered wires to the pins and then soldered them to the headunit and hideaway unit boards. This is a good idea I think because there are enough pins and it has a groind. Only problem i have is that most monitor cables do not have wires at all the pins. if i could find one then this would be great because all together with a long cable it would cost atound €25 and if it gets damaged then it's very easy to replace.
I have the part numbers for the cables, they did three lengths 2,5 and 8 metres I think. But I could not find anywhere that sells it.
