Vw polo 2004 rear wiper arm assembly
Hi I've got a vw polo 9n 2004 model, basically the rear wiper arm has snapped off (it's a long story) is there anyway I can replace it with a new one. I've removed the bolt and upon apply force to remove it with my hands it doesn't want to come off. Is there a specific way it comes off ? Could someone give me tips or tricks on removal.
Adil
  • Views 1.8k
Plusgas would be a good start as I amagine rust may have made it hard to remove. Try not to swing off it too much as you don't want to crack your window. Best to wiggle and pull at the same time I find. If this doesn't work get hold of a mini bearing puller and use that to pull the wiper arm off the shaft
You can buy a wiper arm removal tool from GSF/CAS and the like for about £8
