Polo 6n roof
Is the roof on a 6n welded on as well as the row of bolts from the inside? What they like to remove and where could I get one from to use as a mould to make a fibreglass one anyone???
Thanks on advance
Has anyone got one they could sell me? I want one without a sunroof ideally.
Breaking a 6n in Barnsley, got sunroof though?
Is it easy enough to get off?
Doubt it, should imagine it'll be spot welded, I'll have a proper look at the weekend
Yes it's welded. The bolts I'm pretty sure are only for the ssunroof as Its a seperate assembly.
To get it off propearly the windscreen needs to come out. Will you be laying the fibreglass one over the metal roof or do you plane on replacing it completely?
If you need a roof then go along to a scrapers and ask for a conplete roof clip. the should be able to chop it off at the pilars, this way you will have more to play with and can experiment with it etc. I wouldnt like to guess a price as I haven't bought one but I would imagine that crap value plus a little for getting it off would do it? And this way when your done you can weight the lot in and get some funds back.
As above ^^^ part of the body (strengthening part)
