Hi
I recently had some rust develop on one of my rear light bulb holders, which has wrecked the reverse bulbs connectors.
I was looking at getting a replacement holder but noticed I might want to change the styling of the actual rear lamps.
Is this possible? I have a 2002 MK4 Polo. Would the lamps with the circles as below fit the originals underneath?
Thanks in advance!
!BhEL8Sg!2k~$(KGrHqYH-DgEsNUGmk0cBLHko(7
$(KGrHqZHJFMFDVPsTHU3BQ9s4umGd!~~60_12.J
  • Views 961
  • Thanks, Dean! That gives me some hope then, that this can be done! I shall investigate... If anyone else has further advice, I'd really appreciate it as I don't want to unnecessarily by new lamps!
There's a silver polo by me that had those same lights and now has the circular style ones so it is possible, however I'm unsure if there's any messing around involved. I'm sure someone will know though. . .
Thanks, Dean! That gives me some hope then, that this can be done! :smile: I shall investigate...
If you had to adapt the wiring it would not be a hard job anyway, and somebody with some time and a 2002 mk4 should be able to test and tell you what wires do what exactly.
Did u have to mess with wiring. Also thinking about changing mine.
