rear seat rattle that only stops when the seat is in use.
Hi,
I have a June 2012 Polo Match. When driving on anything other than a very smooth road, I have a annoying rattle that appears to come from the rear seat area directly behind the driver. . It only stops if someone is sat in the seat. I 've take out the parcel shelf and everything out of the boot area and it makes no difference.
Has anyone any idea what I could try next.
thank you
  • Views 723
Have you checked if its something under the rear bench come loose
Check the parcel shelf supports arent loose !
If somebody is in the seat it puts pressure on the support between the bench and boot, therefore holding it tight !!!
