Leak Polo MK3 boot
HI all
I'm covering my bases with this post.
I've had a slight leak in the boot of my mk3 coupe. Water is seeping between a join in two panels. I've ringed the area in red.
Crazy question - is it possible for water to seep in through the holes for the bolts that hold the rear bumper on? Mine do look a bit past it. Anywhere else I should look?
yeah it is possible. Make your own rubber washer gaskets out of some bicycle inner tube.
What does your boot seal look like?
The boot seal should be pretty good as I replaced it a few years back. I can't see any water getting in through the seal. I've poured some water onto the boot below the line of the seal (so the top of the bumper) with a watering can, the leak was worse with the bolts out.
I'll try the gasket trick, I've got a few old inner tubes here.
For now I put the bolts back in with a big blob of silicone grease. I'll get some new bolts as well, just in case,
I had the same problem. Water in the boot but it came from the joint in the panels where the rear quarter meets the panel under the tail gate. I filled the seam with a flexible filler as the body work flexes with movement. Drove me mad for a while until I discovered it. Sat in the boot while my wife hosed the car.
HI all
Just an update - I put new nuts in with some silicone grease, no leak yet.
However I've had the car mostly in the garage.
Yeah I had that exact same problem on the passenger side. I could feel some water seeping in when I reached inside above the light.
I'm going to take he bumper off at the weekend, there may be some craks in the panel joins. It had a replacement panel below the light a few years ago - there could be a dodgy join there.
