GARAGE CLEAR OUT - PHOTOS FOR EVERYTHING (MK2f/2 parts-odds and sods-universal bits)
After crashing my breadvan I've gone through a rover metro and now have an '88 1275 austin metro principles edition that I've got big BIG plans for.. all my polo stuff needs to go, and some crap I don't need anymore, so here goes.
The list will be updated every couple of days probably with new stuff etc.
MK2f:
Glovebox Undertray - £5 - (http://www.flickr.com/photos/97947110@N06/10141531046/)
Sill trims - £3 - (http://www.flickr.com/photos/97947110@N06/10141234225/)
Airbox from an NZ, may fit 3f etc. - £5 without MAF sensor - (http://www.flickr.com/photos/97947110@N06/10141335576/)
Towing eye, right hand thread - £5 - (http://www.flickr.com/photos/97947110@N06/10141277005/)
Rear wiper motor - £5 - (http://www.flickr.com/photos/97947110@N06/10141299845/)
Carpets on the arches either side of the bench, dark blue - £3 - (http://www.flickr.com/photos/97947110@N06/10141220934/)
4L washer bottle with pump - £8 - (http://www.flickr.com/photos/97947110@N06/10141506703/)
Centre console, random strap at the back is missing - £8 - (http://www.flickr.com/photos/97947110@N06/10141407685/)
Interior, all seats and door cards (front+rear), some marks and drivers bolster is going - £40 - (http://www.flickr.com/photos/97947110@N06/9675286534/)
Rear parcel shelf supports from a coupe, mint condition, includes the nuts for fixing speakers - £15 - (http://www.flickr.com/photos/97947110@N06/9117281447/)
Tape holder for centre console, semi-rare I'm led to believe - £5 - (http://www.flickr.com/photos/97947110@N06/10151321295/)
CL clocks, in need of bulbs but halfrauds or ebay sell these - £5 - (http://www.flickr.com/photos/97947110@N06/10151496173/)
Door handle trims, plastic - £4 - (http://www.flickr.com/photos/97947110@N06/10191895305/)
Banana trims, one broken clip (2nd photo) - £5 - (http://www.flickr.com/photos/97947110@N06/10161837013/ http://www.flickr.com/photos/97947110@N06/10161584114/)
Rear seatbelt buckles and lap belt - £10 - (http://www.flickr.com/photos/97947110@N06/10161264745/)
Steering column lower shroud, centre screw hole is slightly damaged (2nd photo) - £5 - (http://www.flickr.com/photos/97947110@N06/10161749745/ http://www.flickr.com/photos/97947110@N06/10161629994/)
Door switch, good for fitting boot lights, etc. - £3 - (http://www.flickr.com/photos/97947110@N06/10161413473/)
Small switch blank for under radio - £3 - (http://www.flickr.com/photos/97947110@N06/10161899743/)
Interior door handles with trims - £6 - (http://www.flickr.com/photos/97947110@N06/10161202734/)
Drivers side fresh air vent ducting (I think..) - £4 - (http://www.flickr.com/photos/97947110@N06/10161710444/)
Original VW jack for in the boot, needs a clean really - £5 - (http://www.flickr.com/photos/97947110@N06/10161224194/)
Steering column top shroud - £5 - (http://www.flickr.com/photos/97947110@N06/10161961023/)
Dash speaker grilles - £5 - (http://www.flickr.com/photos/97947110@N06/10161481153/)
Single rear spring, surface rust - £5 - (http://www.flickr.com/photos/97947110@N06/10161980263/)
Exterior door handle and key - £5 - (http://www.flickr.com/photos/97947110@N06/10161450506/)
Rear heated screen switch - £4 - (http://www.flickr.com/photos/97947110@N06/10161485926/)
Large switch blank for under radio, has a flashing LED fitted (looks like immobiliser, for wiring info PM me) - £4 - (http://www.flickr.com/photos/97947110@N06/10161505266/)
Trim under headlight switch, often used for buttons, switches, etc. - £4 - (http://www.flickr.com/photos/97947110@N06/10161443595/)
Ashtray and cigarette lighter holder - £5 - (http://www.flickr.com/photos/97947110@N06/10161541816/)
Both front fresh air vents, like to close themselves on speed 3 sometimes - £8 - (http://www.flickr.com/photos/97947110@N06/10161379524/)
Headlight switch + dash light adjuster, fully working - £6 - (http://www.flickr.com/photos/97947110@N06/10161518295/)
Handbrake trim/gaitor - £4 - (http://www.flickr.com/photos/97947110@N06/10161667753/)
5 Speed gearknob, thread seems to be partially fubar'd but some gaffer tape on the stick seems to fix it - £4 - (http://www.flickr.com/photos/97947110@N06/10161452934/)
Pair of window winders with trims - £4 - (http://www.flickr.com/photos/97947110@N06/10161702723/)
Cam guard, the bit of plastic under the cam cover - £5 - (http://www.flickr.com/photos/97947110@N06/10161491064/)
Rear strut tower plastic caps - £4 - (http://www.flickr.com/photos/97947110@N06/10161740413/)
Fog light switch, 3 position, off, rear, front and rear - £5 - (http://www.flickr.com/photos/97947110@N06/10161627825/)
Rear wiper arm - £5 - (http://www.flickr.com/photos/97947110@N06/10161665685/)
Inner arch trims, need cleaning really and had a small section cut off - FREE - (http://www.flickr.com/photos/97947110@N06/10206230634/)
Blue parcel shelf, no holes - £10 - (http://www.flickr.com/photos/97947110@N06/10206352815/)
Boot mat, will have to be sat in the sun with some bricks to flatten it again - £5 - (http://www.flickr.com/photos/97947110@N06/10206377065/)
Passenger/nearside interior handle trim, 2 clips damaged (2nd pic) - £1 - (http://www.flickr.com/photos/97947110@N06/10206498413/ http://www.flickr.com/photos/97947110@N06/10206509593/)
Rover Metro:
Rear washer switch - £3 - (http://www.flickr.com/photos/97947110@N06/10161286344/)
Rear wiper arm - £5 - (http://www.flickr.com/photos/97947110@N06/10161546674/)
Headlight back covers - £4 - (http://www.flickr.com/photos/97947110@N06/10161693164/)
Gear gaitor - £4 - (http://www.flickr.com/photos/97947110@N06/10206487213/)
Odds and Sods:
2" stainless steel pipe, 10" long - £4 - (http://www.flickr.com/photos/97947110@N06/10141464593/)
Penny board, genuine, pink with purple trucks and blue wheels - £30 - (http://www.flickr.com/photos/97947110@N06/10161887005/ http://www.flickr.com/photos/97947110@N06/10161766854/)
Strip of what I believe is iron, 50cm x 3cm (http://www.flickr.com/photos/97947110@N06/10161631183/)
Prices do not include p+p, although all items can be posted if you cover the cost, offers accepted on most items.
MORE TO COME
Edited by xaxben
  • Replies 29
  • Views 1.7k
Couple of bits added tonight 8/10/13, big update with a lot more stuff tomorrow
Tape holder posted please ? pm on way
Centre console, random strap at the back is missing - £8 will this fit mk2f thanks
Will reply to pm tonight, yes the centre console will fit a mk2f, that's what it came out of haha
PM replied to and huge update done, still a few more things to come!
You don't happen to have the plastic cups that go round the front top mounts?
Sorry I don't :/ Lost one when I was adjusting my clutch in mcdonalds car park and the other one I sold, have a look on ebay
Do you have the cage part of the gear selector linkage?
What year was the car mate? Need the clocks but they need to be from a late wiring car.
91 bud
do you have the wing arch trims bud??
Wing arch trims? Do you mean the GT arch trims or the banana trims? lol
gt arch trims bud
Where about are you mate?
Hi got my tape holder today many thanks great deal ..
Hi everyone, have been busy so haven't had a chance to get on..
Haven't got the cage part of the linkage
Haven't got GT trims only banana trims
I'm on the isle of wight bud
and awesome.
this might be fat chance but are you willing to post the seats thanks
I'm willing to post seats, won't be cheap though
would you be able to get a qoute to post please
could u post some pics of any damage the seats have
Hi mate after thinking long and hard about it it's just going to be too much effort for me to post the seats, you can collect if you want but it will be expensive
UPDATE: some bits removed as sold
Steering column lower shroud, centre screw hole is slightly damaged (2nd photo) - £5 this still available thanks
Yes mate still available £10 posted?
ok mate just noticed you have top one to how much for both posted but wont be until monday now as need to get to bank and i work all day
