Help with engine swap
I need to swap out my old 1.4 16v 100 bhp because all my valves broke took out my camshafts and all my tappers blew of I don't know what happened the engine just cut its self out and wouldn't turn back over but when I stripped it down you can see the damage and I was wondering how hard it would be to swap it for a 1.6 16v gti engine I've already got a gear box for it just would everything else match up
  • Replies 10
  • Views 746
  • runforrestrun
    runforrestrun
    Sounds like you're wanting to swap the whole engine as opposed to converting the 1.4 yeah?
Yeah that's what I want to do buddy. It's on the 6n2 polo there is no difference in the engine apart from the the amount of cc of fuel it takes. So would it be a direct swap or would I need like a new ecu etc
The 6n2 GTI has vvt, so I think you'd need to change the ECU and loom etc.
What's vvt and would my old engine loom not fit?
variable valve timing.
found this post - http://www.clubpolo.co.uk/forum/index.php?showtopic=142326
If I was you, I'd repair your original engine, and if you want more grunt, do the conversion that tom (etches69) pointed you to
This is probably the best place to start mate
http://www.clubpolo.co.uk/forum/index.php?showtopic=213191
Welcome to the Forum. Try using the search function to aid in your information
doing that with his engine would be detuning the gti setup. The 1.4 16v 6n engine is vastly different to the 6n2 1.4 that he has, besides his top end sounds like its mullerd so would be of little use to build a 1.4/1.6 hybrid anyway
I'm on about disconnecting everything from mine taking it out and dropping the gti in I've already got a gti gear box and breaks. So what else would I need to do to make it work cause they look the same there's barely any difference from what I can see. All the posts are talking about dropping then into different years mine is the same year the 6n2 and it's the 100bhp model it's the twin cam 16v
I've never done this swap so couldn't tell you everything, but a few things that spring to mind are engine bay loom, ecu, immobiliser set up (or you could possibly get your immobrmatched to the gti ecu). As I say there is probably more too
Okay is there anyway that I check if the loom is the same like call up vw and I don't even think my one has an immobiliser I've just got the key with the light in I've taken the light out before but that is it that's in there does that mean there could be one on the new engine or is it on the ecu I've had a look through the forum but can't seem to find if some one has done this to there.
