Air con not working
hi Guys
just bought my first car 2003 1.2 all was well for the first week, then all matter of things started happening
  1. I'm get a whirring noise but tends to disappear when I press the clutch
  2. the air con doesn't work lights up ok
  3. cant change position of the air vents only comes out from the top vents
  4. rear wheel cylinder started leaking
  5. car barely ticks over from start feels as if its likely to stall
  6. no radio reception on mw (like to listen to radio 5 live)
Can anyone help before my old man makes me sell it. he recons I've been had
  • Views 775
Popular Days
Sounds like your old man may be right.
Clutch noise sounds like possible release bearing.
Air con ever been regassed? Coming for gas to run out if never charged but you could possible also have a leak which could be anywhere (pipes/condenser/rad etc)
Air vents sounds like the wire/cord to change the setting/pull the flap on the heater matrix has either disconnected or snapped off.
Replace the cylinder if it's leaking, I would personally put new brakes on if it has leaked over them just to be safe but you could just clean them up.
So many things could cause poor running (coils, coil pack, spark plugs, leads etc etc)
As for the radio may be worth pulling it out and making sure the aireal hasn't just popped off the back of he unit
These are all my opinions don't take them as sure things,
Hope this helps
