175,000 on a 6N 1.4 Will it die soon?
Seen a 6N Harlekin I quite fancy. Its rather tidy, and quite cheap, but the only problem is the mileage. Its 175,000. Says its still going strong but how long will the engine etc. last?
  • Replies 8
  • Views 864
  • I've got a low mileage 1999 1.4 block from a 6n, last of the iron blocks with the direct drive pump, i plan to make a 1.6 AFH with it but with no plans for the engine this block can be sold. Its not
You literally can't put a distance/date on how long it'll last. Obviously better service history would indicate its been looked after and maybe check the gearbox/clutch/pedal box has been done and how long ago
Other then that it's just down to how happy you would feel buying it
Thier quite rare if you like it and it drives and stops good then buy it if it's a good price
If your not a mechanic get one to come with you and have a look
Sometimes higher mileage cars are better as they have been run properly. As long as its been serviced regular then it should keep going. 175k is well impressive though.
Cheers guys. Asked more about it. Doesn't have a lot of history so no idea how well looked after its been. Also has had welding in the past and has typical 6N rust, that put me right off.
My polo had 175 thousand on the clock. The main issue I had were the sills. It failed the mot due to the fact it didn't have any! So that's what I would check.
Its not going anywhere, so if you buy the Harlekin and the bottom end does go then you know where there's a good spare ;)
if the rest of the car is sound condition then get it and plan to replace the engine when it dies
tbh any car that age could have seen plenty of neglect and abuse and be ready to fail with any milage , engines are pretty cheap and not too hard to swap over
aslong as u keep the service intervals upto scratch anythings possible
i had a mate who had a 6n 1.4 8v who ran it from 90k.... he ended up selling it with 198k only with a isv needing attention.
less said about the gearboxes and hubs were a different story tho lol
