Replacing Headlining
I am interested in replacing my headlining in my 6n2 with something a bit different but how easy is it to do?
Has anyone got pictures of the process or any "Do's and Dont's"?
Any tips/info appreciated!
  • Views 806
Remove the A,B and C pillars (you will have to undo top of seatbelts to get these off)
Remove sunvisors, interior light and all grab handles
Open all doors and boot and peel the door seals away from roof lining
Remove roof lining through boot
Took me about 15 mins.
Then you can wrap it or paint or whatever you want
So it is literally as simple as it sounds - I'm assuming its harder to get back in than it is taking it out?
It's simple but when pulling it out and in you do need to bend it a little to get it out also best to have another person with you for this.
Getting it in isn't any harder, just reverse to removing
Awesome - cheers mate!ill post up a pic once it's done, maybe Sunday!
If your wrapping it, make sure you use a good glue and put weights into corners and edges.
Otherwise it will lift/sag, unfortunately this has happened with the trimmed headlining in mine.
