New and need help with idle please?
I'm new to club polo so hello all:) anyways I've got a polo 1996 1.0 (first car) and my throttle body went over the weekend as it was Erving erratically (usual polo symptoms ) I purchased a second hand one and now my car won't idle and when it does it about 500rpm , I really need help and want her running right again
  • Views 504
If you have Vagcom then the new TB will need running through basic settings (098), if not disconnect the battery for 10 mins.
You may also have a vacuum/ air leak. ;)
I had the same problem was down do an air leak and my O2 sensor had gone in the manifold in my 6n2
