Will be breaking car soon i need to strip it and get it all in order. i will get photos of everything and prices so just keep your eyes on this post.
Edited by jinjur
  • Replies 40
  • Views 2.7k
Location?
Pm'd
External door handle inserts. You know the black plastic bits. Also the window seals that run along the outside of the wind down window.
Clive
Clive
yeah think i can do them can u specify which seals
Edited by jinjur
Window seal on the window that winds down. Stops the water running down the window into the door. Must be straight and making a good waterproof seal. The ones on my car are perished.
Yeah can do them mate and the handle covers.
How much posted please?
Do you have the cage part of the gear selector linkage?
alright jinjur do you have plastic wheel arch cover things and how much collected?? let me know bud text me on 0seven971394182
How much for cam
Have you still got thet engine? i need a bottom end
Hi mate. Got a pic of the rear bumper? Is it undamaged with no broken clips or scuffs?
I need a gt fuel pump under car if u have one pm me or call 07732035408
Is the windscreen seal oem and in good nick, and the screen as well if can :)
where abouts are you ? and how much for the doors?
How much for the engine, gearbox, ecu, wiring loom, airbox?
Thanks Rob
Hi mate how much for the complete pedal box posted. Need asap as my clutch pedal snapped at the back. Thanks
Rob
Hi, iam desperate for the ecu rely under the bonnet?!!! The number. Is 321919505a please tell me you have one!! And if so how much posted please? Thankyou
Hello mate, have you got the handbrake cable assembly that sits just behind the fuel tank that pulls the drum cables when you operate the handbrake lever ?
If so how much posted ?
Regards
How much for the throttle position sensor posted to Manchester?
Hiya mate, I need the front struts and springs if still available and in full working order?
cheers, Alex :-)
What's left of this please?
How much for the rear beam with anti-roll bar?
Rocker cover & bolts?
