6N2 water leak issues
I seem to be getting alot of water leaking from my drivers side door. I can see the top of the arch on the inside of the car is a bit damp upto the side pillar but the rubber seal doesn't look damaged so not sure how water is getting in. I also put a cover on my car and to my amazement after removing the cover there is a puddle of water on the front mat and some has gone to the passenger mat. I've got a sunroof but cant see any leak from there. Any suggestions?
Edited by yasir152
  • Views 4.8k
this could be your heater matrix i had the same problem in my 6n always had a puddle in passenger foot well, keep a eye on your coolant level and if you get a white rag and just put it into the water on the carpet to see what color it is .
If it were the heating matrix then how would the top of the arch where the window is be damp?
Maybe someone has crudely attempted to break into your car and given up? Sometimes thieves will try and bend the top of the door back to gain entry. Just check there are not creases in the door edges.
Sit inside the car with the door closed and get a friend to drench the top of the door with a hosepipe/bucket and see what happens.
or the drain from your sun roof could be blocked as the pipe sometimes comes down the inner wing but get blocked up with dirt from the road
Okay so I've done the water test and found that water is leaking from the seal on the roof near the drivers door. From the inside, the part of the roof next to the drivers door is damp and it looks like this is where water is coming into the car. I can't see an damage on the rubber seal but it looks like I'll have to replace the whole strip which goes along the roof on the right hand side of the car. Anyone had to do this before and know the cost of the seal?
I managed to find the cause of the leak and it was due to the pollen filter being very filthy and also near the wipers it was very dirty, i managed to push a coat hanger in the holes next to each wiper and alot of rubbish came out. i have found though that the carpets are being to get damp again. even though i cleaned out the wipers and pollen filter area I'm not sure what is causing the water to come through to the passenger footwell and driver footwell. its defnitely from underneath where the foam is as this is where it was drenched with water before i dried it out but its now started again though not so severe.
