Polo G40 Engine box charger and loom with ECU Poss splitting
I have been splitting my Engine due to no one wanting it complete.
So I have listed parts below (Some are also on ebay)
Charger, slight damage (crack) to one casing £200
Bare engine but will include Oil cooler unless sold before hand - £250
ATV Gearbox - £250
Inlet Manifold with Injectors £100
Throttle Body still with wedges - £60
I will update pics once I find my Camera.
Edited by jonny_gt
  • Replies 16
  • Views 711
  • pitchpolo94
    pitchpolo94
    this may come across a bit daft but would you be interested in swapping a car for it? pm me for more info
any idea how long this has been sat outside for??
Hi, only sat outside for about a week between being moved from storage to my house. But it has always been well covered. Gearbox has now been split off it and a few other things removed but still there, just to make it a bit lighter for me to move it. Engine turns over easily by hand.
Is it an ATV code gearbox? If so and if you are considering splitting it I may be interested in having the box off you.
Yes it is indeed an ATV Box, was refurbed not long before being removed from the car.
How much would you want for the box alone?
I was offered £350 for it when the whole lot was on ebay, but I didn't want to split it then. I have started to list the bits on eBay now. So I am open to sensible offers on it.
Hi mate, i know its not in the ad, but is that an oil cooler i see? Do you have the cooler, pipework and sandwhich plate? If so, how much posted?
Hi, the pipes aren't in the best condition and the braiding has come away (isn't leaking though), but everything else is there. I'd reckon on £45 posted.
Loom and ECU now sold, everything else still here.
How much are you looking for the engine with/without charger? Not inc gearbox
Cheers Pal
Edited by physicsfool
Cheers Pal
Bare engine £175 or with Charger £350
Any info on charger? Wunt mind a couple of piks of the inside make sure it all looks as should
I have been unable to get the charger off of the engine due to not having a big enough Allen key!
The charger was said to have been rebuilt about 6 years ago now, It didn't have a lot of use, it turns over freely enough, but I would probably recommend a light refurb. I'll update if I can seperate the 2.
How much you lookin for the charger on its own? With it being sat in damp conditions I'm wary as the scrolls can be delicate on these. Easy enough to take apart mate. Pm me if you do as I'm interested. Any piks of the outlet side without the elbow on to see if theres been portin or not?
How much for the engine alone? And would you be willing to have it couriered if I arranged for one? Cheers
