085 diesel gearbox (6N, Cordoba)
As above.
Edited by mk1
  • Replies 37
  • Views 1.4k
They are just 1 litre 5 speed for the mk2 and mk3
Sorry?
Cem or ahz code from a mk2 or mk3. There is no specific diesel mk2/3 gearbox
6Ns had 085 gearboxes, too.
Are you saying that all mk2/3 diesel models had gearboxes from 1 litre petrol engines?
085 is that rod and cable clutch
Yep.
1.9d is a big block in the 6n, in which case its likely to be an 020 type gear box. Starter motor in different place.
Does the petrol bellhousing not mount up to the 6n 085 diesel gearbox to mount to a regular small block?
I've got both types of boxes
I've got a 80k miles 6n 1900cc diesel box here
How much?
6n still uses an 085 box on the 1.9 D but it's very long geared. Here's some codes: CWT, DCH, DCT, DED, DXF, DXG, DXQ
The mk3 with the 1.4 D used the 8P/CEG gearbox, 1.3D in the mk2 used an AHD (GT box) the Seat Terra van with the 1.4 D used the AHZ or CEM (1.05 5 speed)
That's really insightful, thank you.
I'm fitting a 1.4D from a Seat Terra but want longer gearing to bring the revs down a bit.
Do you have any ratios to hand for any of those gearboxes?
£60 takes it
Where are you?
scotland but could orginise a courier for you
Whereabouts? I drive up to Rosyth every now and then if that helps.
I'm in bonnybridge,falkirk which pretty close,i could meet you in rosyth no probs
i can help you out with a mk2 polo windscreen also if you still need one
Edited by low bay
got a chc from a mk3 golf diesel if any use, after £40 and I'm in manchester
I go via the A701, so could pass by Bonnybridge on the way. Still need a windscreen so that would be good. All depends which car I'm in on the day!
Just to keep my options open, is the CHC a 085 gearbox?
i dont know the difference I'm afraid,
No worries.
Can you check the gearbox code on yours and let me know what it is please?
I've read the code twice when I've been at my garage and forgot it by the time I've got home,will write it down and get back to you lol
the code is dch
