Mk2f coupe speedo dials/ tachometer/ clocks upgrade?
Hi guys,
Is it possible to install a tachometer into a standard Mk2f coupe speed dials (etc) set-up? And is it possible to install the digital clock into the dials also?
Has anyone done this before, and if so how do you go about doing it?
Thanks a lot,
Nick
  • Replies 9
  • Views 2.6k
Just swap an entire set of GT/G40/Genesis clocks in, much easier...
My car has only done 68k, so I want to keep the same clocks.
Is it possible to take them apart and insert a tachometer/ digital clock though?
Regards,
Nick
Yeah it is mate, I've done this before take the clocks apart and it literally lifts out and slots back in. No messing about etc.
I think what you want to do is put your speedo into a new set of clocks rather than put a tacho and clock into your own clocks?
Easier to just take your speedo out of the clocks and put them into some GT/G40 ones like Derskine said man, 6 screws thats it.
Thank a lot!
So its literally that simple(?)- The Speedo comes out of my clocks and I can insert my speedo into a G40 unit?
How does the wiring work with the tachometer, as my car doesn't have one at the moment? Are there plugs in there or does it need some wiring?
Cheers guys,
Nick
Hi mate,
Is it is simple as that? You can just replace the speedo in the 'clocks' set-up? just by taking it out and putting it into a Gt one?
Is there any wiring involved- how does the tachometer work if there wasnt one in the car before?
Thanks a lot,
Nick
P.S. If anyone else knows please drop me a line?.
There should be a plug for the tacho behind the clocks, I believe all mk3s already have the wiring in place, just some don't have a tacho
