Mk2F seats in a Mk1
Went to put my g40 seats i had spare in my mk1 which has no seats and i have found that the pin that is operated by the handle to move the seat forwards and backwards in the rails is on the opposite side to the mk2f, was wondering if anyone has come across this before as i would like to fit them, Cheers Jordon
  • Replies 10
  • Views 829
Yeah I've heard of that. Cant you swap it around normally?
doesn't look it, i cant look at the car as its not kept at home but i think there was a little sleeve attached where the pin slotted in and that was on the wrong side
Yep, done the conversion on corrado seats for my derby and mk2f seats for my early classic. I cut off the bracket and welded to the other side, I recall a p clip screwed to the front part of the seat which swapped to the other side. Without a mig welder I think you'll struggle.
As in cut the brackets off and swap them left to right or flip them around?
Not sure what you mean by the p clip but i'll have a look
Edited by JordonVW
Yep, cut the rear bracket that the seat adjuster pivots on and weld it to the other side of the seat, the front end of the adjuster sits in a p clip which unscrews and there are holes on the other side of the seat frame to use. On mine, I also set the height adjuster to its lowest setting and welded it there and cut the height adjuster off as I didn't need it.
All this was over five years ago now, I don't have any pics - sorry.
Edited by Vic
ahh you are talking about modding the seats, i thought you meant modding the bracket on the car which might be easier if you chopped them out of a mk2f and welded them in?
The rails are a nightmare to line up if welding them back into the floor - if they're out the seat is harder to slide back and forward
Mk1's and early mk2's were like it, it changed when they changed manufacturing to Spain. I've been planning on swapping the levers on the seats from side to side, but how do you get around the height adjustment mechanism?
Mines a german model but the normal side. So not strictly true!
If it was me id modify the car rather than the seats, but i like changing seats alot so itd help in my case
I'd also like to mod the car rather the seats, seems more of a simple way round it really. And I'd like to swap the seats at some point and I can't see myself ever putting in mk1 seats, maybe Rado seats
