6N2 Gti Rear Brake Setup - Ideal 6n upgrade
I have the much sought after rear disc conversion from the 6n2 Polo GTI.
These are the much improved setup from the poorly designed Mk2/3 Golf tapered bearing. These are less prone to failing and can handle camber for a lot more miles than the old setup. Also makes changing discs a lot less of a hassle.
These will bolt straight up to the Mk1, Mk2, Mk3 Golf. Corrado. All Polos pre 2002. Lupos, Arosas, along with similar age Ibiza and I'm sure a lot more.
Note these are 4x100. So not for the GTI Mk3 or VR6 Golf/Corrado.
These do however come with the Mk4 alloy style calipers so you will need conversion flexi pipes as these use a banjo fitment and not screw in.
This kit comprises of:
Stub axles
Dust guards
ABS sensors
Hub and bearing
Discs
Carriers
Calipers
Pads
This kit will be sold complete. I will not brake it up.
Price: £90 collected. £100 delivered
07590991310
Edited by valley
  • Views 179
Location?
Milton Keynes/ Bedford Bud
PMd... Ill take it dude.
SOLD
