mk2/mk2f and g40 parts for sale
Having a bit of a clear out need some room:
HZ 1.05 litre engine and 4 speed box came out of my mk2 bready because I'm now running a 1.3 on bike carbs it ran perfect when i took it out its been out for 3 weeks now so will be fine to put straight in another car the engine and box has done 80,000 miles i did a cambelt at about 12.000 miles ago iir i can check that one but i know it wasn't that long ago. tbo the engine is bullet proof it would go on forever if you wanted it too, i changed the oil a filter every 10000 miles and it was last done 2000 miles ago spark plugs are 5000 old, i also have 4 speed selector and loads of other bit with it comes with both manifolds, clutch, down pipe, carb 1b3 piarburg pancake filter housing etc. I'm looking for £90 collection only
I'm HAPPY TO SPILT IT NOW SO ANYTHINK YOU NEED JUST ASK
also have a mk2 full standard patten exhaust that came of with the engine done 10,000 miles loads of life left, £10 collected
standard hight mk2 front and rear springs and two rear shocks and one basically new front shock without strut just shock, £10 collected
1.3 2g camshaft very good condition £8 collected
2x 1.3 2g/mh inlet manifolds with heater elements £10 collected each
Weber 32TL manual choke carb to replace the 1b3 peirburg auto choke carb i bought this brand new from webcon direct and used it on the HZ engine that I'm selling its done just under 15.000 miles since new it will come with everything u need to convert it from the 1b3 and will come in original book with full fitting instructions you wont believe the difference these make! it cost me over £200 I'm looking for SOLD
mk2 false floor made from MDF with two securing bolts at the front to stop it from sliding forward (bolts to where the seat would have bolted too)
10 collected
mk2 single light grill in hella box all clips in tacked, SOLD
power flex ARB bushes bought these not long ago but ended up using blocks instead loads of life left 15 collected
AW Tracksport front mount intercooler for G40 got this for my project car but i have different plans now fit nicely between chassis legs, 45 collected
also have a MK2F injection fuel tank came out my g40 I've got a new one for it so its gonna get chucked if it not taken it has surface rust but it will probs last for a few more years yet, £FREE
early mechanical head rocker cover gasket brand new SOLD
located Basingstoke RG22
i can post smaller things and deliver larger things at cost and if u dont live miles away!
any questions please ask :)
61EB9A34-884F-4564-B70F-A6AC32084C6C-515
67FB0188-F519-42A7-898F-80F707676557-515
F95F0C5B-B505-4BC2-B4BE-852271B15CF7-515
20D95DEB-34B1-40B3-BE5D-A930B261E694-515
3A9C61BB-D96A-442B-A5BE-F01288BC9E67-515
0D9BCA24-9F7B-471B-8611-65811E633020-515
EF6A17D6-6338-47F9-8838-729CA442F8BA-515
239EA9D2-1B83-4B84-832C-3531629643F0-515
335CED20-AB62-4F20-BAEF-CAA82DD11180-515
F5A18266-5787-4125-9D84-A8D40B3EF027-515
06C9F1C8-7ABE-437B-8FC2-75148E9A1574-515
Edited by RyanC
  • Replies 24
  • What's the part number mate? I'll have a look at them tomorrow defo off a 2g tho
Are they definatly the large port 2G manifolds? I'll have one if so
If you post a pic of the gasket flange and ports i'll able to see mate
Okay I'll get one for the weekend
At least one is definitely 2G as I removed it from my 2G engine.
I like Victor Reinz.
£5 to give to charity of your choice + p&p at cost for the free mechy head gasket?
dvderlm: I've message u the postage cost
mk2coupe: they are both 2g manifolds I'm not able to get a picture atm but if u want one then i will get one later?
Edited by RyanC
Long shot, but is carb still available?
The weber yes it is
Oh please say that weber is still for sale! Been looking for months, how much you lookin for it, and does it come with a manifold? As my solex carb has broken cheers
I've talked to you on FB already lol price is the same as what it says at the top, no didn't come with manifold
Wish you was closer, I'd of taken the fault floor.
I can post but will cost a lot probably
Might want the false floor
Just pm me if u want it
Powerflex ARB bushes, 15posted?
Yes mate don't come with metal brackets though just bushes :) pm me if you want them
Is the 2g manifold the GT one? If so after a GT one if till available?
No a 2g manifold is for carbed engines gt one is completly different for multi point injection engines
Rocker cover gasket gone
Single light grill sold
Also have a peirburg 1b3 carb 10 collected needs a clean up
What g40 parts are left pal??
Just the intercooler atm haven't desided if I'm going turbo or sticking with that charger yet but when I do if I go turbo all my charger related stuff will be up for sale
