9n door panels
Hey,
I'm looking to purchase new door speakers for my 9n and was wondering if anyone knows of any guides for getting the door panels off.
Not sure if there was a special way of doing it without breaking any clips, or if it's simply a case of prising gently with a screw driver.
Cheers in advanced !
  • Views 675
4 torx screws at the bottom of the door card. Then in the vertical black handle part (on the inside of the car) not the bit you use to open the door as well. You can pry that handle open as it comes apart. There's 2 more screws inside and then once those are undone it's just on clips. Buy some clips before hand tho as most of them break when you pull the door card off. That's the best explanation I can give. If all else fails go buy a haynes manual :)
