Mk2f body work maintenance- side skirts.
Hi guys.
Simple question regarding the side skirts on a Mk2f coupe.
The model I've had for the past 8 years the CL, so didn't have side skirts/ wheel arches etc initially. Now I'm using it as a project I've done some upgrades. Side skirts were put on, along with the wheel arches etc, and a new engine will eventually be put in.
I've just been out washing the car as its going into the garage for some work, and thought that water might be able to get into the small holes I drilled for the pop rivets (to attach the side skirts). I don't know how this will affect the car with rust etc in the future- can the water escape from where the holes were drilled?
So question is, is there any need for some sealant around the pop rivets that I attached the side skirts to the car with? or are they fine as they are, and I dont need to worry about water getting into the body work and rusting the car in the future?
[Never going to sell this car so want to maintain everything as best as possible]
Regards,
Nick
  • Replies 11
  • Views 1.2k
When I took the sill trims off of my gt, most of the holes had become rotten and wouldn't hold a pop rivet anymore
Definitely worth sealing them up
Edited by derskine
What about water getting inside?.. dont know how if there is a way for the water to escape once gone through the holes(?), and will this rust the underneath of the car?
There are drain holes in the sills, but they're not great, all polos will most likely need new sills at some point, its quite hard to prevent them corroding as they rust from the inside
Thanks mate. Will get on sealing them up. When I drilled the holes there was quite a bit of space around them, so definitely need some sealant.
Thanks a lot,
Nick
You drilled the holes? Mk2fs already have the holes they're just covered over so need a poke with a sharp point. With original holes its unlikely that much water will get in around the rivets, the sills are cavity waxed which should meant the water will run through and out the drain holes. The biggest problem will be where the rivet grips the sill it damages the paint, meaning rust which rots out that area.
Personally what i did, made sure there was fresh paint like hammerite around and in the holes, fitted the covers with the correct size rivets. I have then pumped more cavity wax inside the sills which will atleast protect the insides. I really put plenty in there and squirted it everywhere.
I used Dinotrol cavity wax, 1 tin each side (doing sills, inner rear wings, and the rear jacking point cavitys etc), you'll need the long injection hose.
My 1991 GT has two grommets which can be removed. I filled my sills with waxoyl that ran out of the drain slits. Seems to have done the trick. Used under seal on the outside of the sill and all is well. Not bad for a 22 year old car.
Always weary of filling the sills with waxoyl, if it needs to be welded in the future its a big fire hazard, not to mention the waxoyl messing up the welds
Point taken. My garage recommended filling all cavities.
Pretty sure some cavity wax's aren't flammable? I had to chop and weld the sills on mine so it needed something on the inside either way. But i'd still recommend it, just make sure the sills don't need welding first.
It'll last better than if you don't, but it's not 100% effective, or cars would never rust
My point is, if you fill them with wax and then they rust from the outside, just a small hole perhaps, you have to take the whole sill off to avoid it going up in flames, when you could just patch it up otherwise.
This is just my personal opinion, I don't cavity wax mine, however I have no problems replacing or patching a sill
Ahh yes i completely agree, i was going from the assumption that if someones gone to the trouble of waxing the insides they'd keep an eye on the outside for rust. Like myself, cut the rust out, did the outside all properly so cavity waxed the inside, i'll just keep an eye out to see that surface rust doesn't reappear anywhere. Having more wax in the sills would make things more interesting if it comes to welding most definitely.
